未来的新靶向药物Prof.Alex A. Adjei演講摘要
12416 28 以马内利 发表于 2011-10-22 21:16:22 |
上网无意搜索到bk叔叔的博客  这个就复制下来吧,我觉得有点点参考意义
e Perspectives on Targeted Therapy for Solid Tumors
Alex A. Adjei, MD; PhD
Roswell Park Cancer Institute
Buffalo, NY 14221
Advances in genomics and tumor biology have led to the identification of multiple  proteins  and pathways involved in carcinogenesis and the  maintenance of the malignant phenotype, which are targets for cancer therapy.  The most studied pathways are the PI3-Kinase/Akt  and Ras-raf –MEK pathways. A number of targets have been identified in this pathway including IGF-1R, PI3-Kinase, Akt, mTOR, MEK, Raf and c-MET (Table 1). Multiple agents targeting these targets are in the clinic. In spite of the initial enthusiasm that greeted the advent of  these  targeted agents, efficacy has been modest. The few successes are with VEGF inhibitors (bevacizumab, sorafenib, sunitinib, pazopanib), EGFR inhibitors and mTOR inhibitors. In addition only a few tumor types have benefited from these agents. A number of negative studies have been performed and a number of lessons have been learnt. It has become clear that successes may be achieved with selective agents targeting protein products of actvating mutations, multitargeted agents or combinations of agents. Examples of these approaches will be discussed and c-MET inhibitors will be utilized as a paradigm.
TABLE 1  : Novel Targeted Agents in the Clinic
人生没有如果,只有后果和结果
28条精彩回复,最后回复于 2013-2-15 09:26
Michaelfung  初中一年级 发表于 2011-10-22 21:21:32 | 显示全部楼层 来自: 湖北鄂州
给力!!!
升升不息  初中三年级 发表于 2011-10-22 21:27:55 | 显示全部楼层 来自: 广东茂名
谁给翻译下
以马内利  退休老干部 发表于 2011-10-22 21:33:03 | 显示全部楼层 来自: 内蒙古赤峰
我觉得对这种论文研究比较在行的就是bk叔叔和bluest了吧
人生没有如果,只有后果和结果
bkcui  禁止访问 发表于 2011-10-22 22:37:34 | 显示全部楼层 来自: 广东广州
老马  博士一年级 发表于 2011-10-23 00:37:11 | 显示全部楼层 来自: 浙江温州
bk叔叔!。哈哈哈。
bluest  退休老干部 发表于 2011-10-23 09:18:00 | 显示全部楼层 来自: 北京
bkcui 发表于 2011-10-22 22:37
俺绝对没到叔叔的地步,好难过。
BK叔叔公布一下博客地址吧?
英雄武松  大学四年级 发表于 2011-10-23 11:11:21 | 显示全部楼层 来自: 北京
如果这样的话,可以按照能力划分一下辈分,加在图像下面,改变会员-高级会员的称谓,比如憨豆先生最厉害,就称憨叔,bk也厉害,就叫bk叔叔,还有其他大叔、二叔、三叔、大娘什么的,呵呵。
以马内利  退休老干部 发表于 2011-10-23 19:47:44 | 显示全部楼层 来自: 内蒙古
英雄武松 发表于 2011-10-23 11:11
如果这样的话,可以按照能力划分一下辈分,加在图像下面,改变会员-高级会员的称谓,比如憨豆先生最厉害,就 ...
要是按照能力分级,那我就成了  “五孙”啦!
人生没有如果,只有后果和结果
以马内利  退休老干部 发表于 2011-10-23 19:48:22 | 显示全部楼层 来自: 内蒙古
俺绝对没到叔叔的地步,好难过。
呵呵,不好意思,以前总这么叫,所以习惯了
人生没有如果,只有后果和结果
