[基础知识] 给免疫治疗“增效”但不“减毒”的辅助药物(四):白介素
2900 0 自学自救 发表于 2025-4-12 10:05:30 |
一、IL-2+褪黑素7 P9 z  O0 o5 x! D( d
  r% L/ V! S" @/ x% B2 D$ O! c- j
我在《褪黑素(二):IL-2、treg与CD25》文里,已经搜集整理了几个IL-2+褪黑素的临床试验,结果都有不错的疗效,副作用也不大。
' B5 o' Q4 ~( Y/ V1 m, Z那几个临床试验里IL-2的剂量都是每天注射300万单位;相较过去IL-2动辄要注射1800万单位来讲,剂量很小,风险得到了控制。
! n( G$ m/ G: z6 x可以考虑进一步减少IL-2的剂量,加大褪黑素的剂量。4 b5 O1 Y  {1 g
% w. P: R& w: g* y* f
二、IL-12, L) F* E# c+ Q- ?. w. p+ ^5 X$ k
" e( J( H4 R( ]6 d  SIL-12的问题是全身施用毒性过大。
  H. y3 I; G7 [  l. L- J解决思路是瘤体内或者瘤周注射很小剂量的Ad-RTS-hIL-12,同时口服IL-12激动剂Veledimex。
0 R* W/ o& ?2 |" V1、《Regulatable interleukin-12 gene therapy in patients with recurrent high-grade glioma: Results of a phase 1 trial》5 A! {+ g: g( A
We assessed the safety and biological effects of an hIL-12 gene, transcriptionally regulated by an oral activator. A multicenter phase 1 dose-escalation trial (NCT02026271) treated 31 patients undergoing resection of recurrent high-grade glioma. Resection cavity walls were injected (day 0) with a fixed dose of the hIL-12 vector (Ad-RTS-hIL-12). The oral activator for hIL-12, veledimex (VDX), was administered preoperatively (assaying blood-brain barrier penetration) and postoperatively (measuring hIL-12 transcriptional regulation). Cohorts received 10 to 40 mg of VDX before and after Ad-RTS-hIL-12. Dose-related increases in VDX, IL-12, and interferon-γ (IFN-γ) were observed in peripheral blood, with about 40% VDX tumor penetration. Frequency and severity of adverse events, including cytokine release syndrome, correlated with VDX dose, reversing promptly upon discontinuation. VDX (20 mg) had superior drug compliance and 12.7 months median overall survival (mOS) at mean follow-up of 13.1 months. Concurrent corticosteroids negatively affected survival: In patients cumulatively receiving >20 mg versus ≤20 mg of dexamethasone (days 0 to 14), mOS was 6.4 and 16.7 months, respectively, in all patients and 6.4 and 17.8 months, respectively, in the 20-mg VDX cohort. Re-resection in five of five patients with suspected recurrence after Ad-RTS-hIL-12 revealed mostly pseudoprogression with increased tumor-infiltrating lymphocytes producing IFN-γ and programmed cell death protein 1 (PD-1). These inflammatory infiltrates support an immunological antitumor effect of hIL-12. This phase 1 trial showed acceptable tolerability of regulated hIL-12 with encouraging preliminary results.
' }2 M9 \9 m) C1 H$ @! p1 ?; G2、《Combined immunotherapy with controlled interleukin-12 gene therapy and immune checkpoint blockade in recurrent glioblastoma: An open-label, multi-institutional phase I trial》
# D% ]) A! q9 ]7 HMethods: An open-label, multi-institutional, dose-escalation phase I trial in rGBM subjects (NCT03636477) accrued 21 subjects in 3 dose-escalating cohorts: (1) neoadjuvant then ongoing nivolumab (1mg/kg) and VDX (10 mg) (n = 3); (2) neoadjuvant then ongoing nivolumab (3 mg/kg) and VDX (10 mg) (n = 3); and (3) neoadjuvant then ongoing nivolumab (3 mg/kg) and VDX (20 mg) (n = 15). Nivolumab was administered 7 (±3) days before resection of the rGBM followed by peritumoral injection of IL-12 gene therapy. VDX was administered 3 hours before and then for 14 days after surgery. Nivolumab was administered every two weeks after surgery.
0 w9 n: i7 i. ~+ u" J3 cResults: Toxicities of the combination were comparable to IL-12 gene monotherapy and were predictable, dose-related, and reversible upon withholding doses of VDX and/or nivolumab. VDX plasma pharmacokinetics demonstrate a dose-response relationship with effective brain tumor tissue VDX penetration and production of IL-12. IL-12 levels in serum peaked in all subjects at about Day 3 after surgery. Tumor IFNγ increased in post-treatment biopsies. Median overall survival (mOS) for VDX 10 mg with nivolumab was 16.9 months and for all subjects was 9.8 months.; ?" B0 d% V1 }# O9 E6 ^* R
Conclusion: The safety of this combination immunotherapy was established and has led to an ongoing phase II clinical trial of immune checkpoint blockade with controlled IL-12 gene therapy (NCT04006119).3 O* l( I$ R; b6 q) B$ e
3、《Study of Ad-RTS-hIL-12 + Veledimex in Combination With Cemiplimab in Subjects With Recurrent or Progressive Glioblastoma》* H* j, J% ?+ k. y, g, b
NCT04006119这个二期临床试验正在开展。
; ^4 Y2 i7 P8 G4 I* q/ j但是对患者来说,注射很小剂量的Ad-RTS-hIL-12+口服IL-12激动剂Veledimex目前没有可行性。8 q9 Q! U+ H5 Q4 j; ]
有个变通的办法,就是通过用卡介苗来提高体内的IL-12的表达。" n$ `' b- c# \  H) m8 ^% T
《Role of IL-12 in the induction and potentiation of IFN-gamma in response to bacillus Calmette-Guérin》
4 R6 X2 L! @) j) j+ `2 EA kinetic analysis in assessing the potential role of cytokines from BCG-stimulated murine splenocytes showed that IL-12 expression preceded that of other cytokines. Experiments subtracting endogenous BCG-driven IL-12 using neutralizing Ab or augmenting its activity with supplemental rIL-12 revealed not only that IL-12 plays a dominant role in IFN-gamma induction but also that it is normally dose limiting. A striking increase in IFN-gamma production could be generated in both mouse and human immunocompetent cell culture by the addition of even a small amount of rIL-12. Moreover, this same synergistic effect could be replicated during in vivo administration of BCG plus rIL-12 into the mouse bladder and was observed in a patient receiving intravesical combination therapy.. Z  H; Z; `2 v; d' n+ P* X
卡介苗是个用了很久的免疫辅助药物,我在《几种免疫辅助用药(三):香菇多糖、卡介苗》一文里也搜集整理了卡介苗的一些临床试验,结果都是有效的,用了不会白用。口服卡介苗一样有效。
; K5 W/ R% A0 r* X5 k2 x' y, |( @$ F2 o5 a
三、IL-21
5 |/ ~" R4 @! X! G/ \( Q" x1、《Interleukin-21 has activity in patients with metastatic melanoma: a phase II study》% A, C6 D: ]( Q! L7 S9 b4 X% u, r
Patients and methods: Patients with no prior systemic therapy and with limited-disease MM were treated with IL-21 by using three different dosing regimens. Cohort 1 received 50 μg/kg per day by outpatient intravenous bolus injection for 5 days of each week during weeks 1, 3, and 5 of an 8-week cycle. Cohort 2 received 30 μg/kg per day on the same schedule, and cohort 3 received 50 μg/kg per day for 5 days of each week during weeks 1 and 3 of a 6-week cycle.3 C8 ^  V0 q# [* w6 A: h) y
Results: Forty patients were enrolled: three in cohort 1, 30 in cohort 2, and seven in cohort 3. Two patients in cohort 1 and four in cohort 3 had dose-limiting toxicities; all other patients were treated with a dose of 30 μg/kg per day. Common adverse events were fatigue, rash, diarrhea, nausea, and myalgia. Overall response rate (ORR) was 22.5%, with nine confirmed partial responses (median response duration, 5.3 months); 16 had stable disease (median response duration, 5.3 months). ORR did not appear to depended on IL-21 receptor expression or BRAF mutation status. The median PFS was 4.3 months and median overall survival (OS) was 12.4 months (95% CI, 10.09 to 17.81 months).
0 l% V  k3 M7 A' o; z" J; wConclusion: The ORR to IL-21 is 22.5% for first-line MM and warrants further investigation. The favorable PFS and OS suggest that this is an active agent in comparison to both historical NCIC Clinical Trials Group data and data from meta-analysis of Cooperative Group phase II trials.' g) K' q; ^) ?
2、《Phase I study of recombinant interleukin-21 in patients with metastatic melanoma and renal cell carcinoma》
0 q* P; C& j: YPatients and methods: Patients who had one or fewer prior systemic treatments for metastatic MM or RCC were treated with rIL-21 administered for two 5-day cycles on days 1 through 5 and 15 through 19 of a treatment course; rIL-21 was administered by rapid intravenous infusion in an outpatient setting. Cohorts of patients received doses ranging from 3 to 100 microg/kg/dose, and an expanded cohort was treated at the MTD. Patients with stable disease (SD) or better could receive additional treatment cycles.
( L: C3 ]9 @  l1 Q2 O. qResults: Forty-three patients were treated (24 MM; 19 RCC), including 28 in the expanded cohort. Dose-limiting toxicities consisted primarily of transient grade 3 laboratory abnormalities. The MTD was estimated to be 30 microg/kg. The most common adverse events included flu-like symptoms, pruritus, and rash. Twelve patients received up to five additional two-cycle courses of treatment without cumulative toxicity, except for one patient with reversible grade 4 hepatotoxicity. Serum concentrations of rIL-21 increased in a dose-proportional manner. Dose-dependent increases in soluble CD25 reflected lymphocyte activation. Antitumor activity was observed in both MM (one complete response and 11 SD) and RCC (four partial responses, 13 SD).
# ]; e, m8 v/ T( yConclusion: Outpatient therapy with rIL-21 at 30 microg/kg was well tolerated, had dose-dependent pharmacokinetics and pharmacodynamics, and was associated with antitumor activity in patients with MM and RCC.
& ?( y* S* h! A/ d& @6 y3 V
